Not the greatest of pics trying to take picks of chrome on chrome up close dont work well ..
Somethings let me tell ya the guy who puts these together at HD dont get paid enough course hes probably at a bench and im standing next to it in a garage but its TIGHT..
Heres how ya start Blah
Remove upper and lower screws
Once ya split the housing and remove the screw holding bracket.. couldn' get a pic of screw in the upper housing to come out .. got 20 blured pics
Remove switch caps this is what ya get
Cruise and radio plugs pull off with tool in next pic
the switches and housings come with the tool
This is lower bracket holding in cruise switch
then you reinstall the turn switch and brake light switch
dont forget the copper bent piece that holds the switch tight ..can ya see the 3 screws holding everything in and the zip tie what a treat
On thing i didn't use that came in the chrome switch kit are the screws to short by the time i had compressed the housings back to the bars i could barely grab threads .. so ill pass on using these went with originals.. funny the kit HD sells as chrome replacement screws are different and longer than the ones in the switch kit
Also you do have to remove the clutch and the master cylinder on other side to get the housing far enough apart..
I took probably 100 pics trying to document it but 3.4ths didnt come out to much shine..
also something i was disturbed with at first were the gaps on the switches and housing then are large .. so i got the factory housing and switch and see its the same you just cant tell cause they are black ya cant see gaps unless you really look .. so basically the handle bar switch's are not sealed at all
Another thing i did was install a pushbutton on the started that you can also start up with again pics didn't come out well
the screws in the kit also didnt work wrong pitch so i reused original one .. different pushing in the button on starter to fire up bike ..
Give yourself at least 1 - 1 1/2 on the switch and housings and a few breaks and some why did i do this time ..
the push button on starter 20 mins tops
