Chrome Project
Discussion in 'Touring Models' started by Gezzer Glide, Dec 8, 2010.
  1. Gezzer Glide
    Gezzer Glide Active Member Contributor
    341
    Going from this:
    [​IMG]
    To this:
    [​IMG]
    I found these at a local shop for $70. There not perfect but will do just fine and save me about $175
    Had to make a few new tools to remove some bolts on the rear cylinder. I ground down a 7/16 and 1/2 in socket to fit a 7/16 end wrench. Will also be needed to set the torque on assembly.
    [​IMG]
  2. TripleJ
    TripleJ Senior Member
    1,081
    8
    Looks like a good find and now you have some extra cash for more Chrome :D
  3. Jack Klarich
    Good score and pretty creative with the tools:s
  4. mca1989
    mca1989 Member
    22
    how are you going to torque it ?
  5. Hoople
    Hoople Account Removed
    7,198
    34
    Could use the combination wrench as an extension to the torque wrench & then use a torque wrench extension chart.
  6. Gezzer Glide
    341
    The reason I used a 7/16 wrench is because my torque wrench fits the box end of the 7/16 wrench. The book says if I keep the 2 wrenchs at 90* it will cancel the multiplier effect and not over tighten the bolts.
  7. Gezzer Glide
    341
    Old and dull :(
    [​IMG]
    New BLING :D
    [​IMG]
    And for under $200
  8. Cyclops
    Cyclops Active Member
    371
    Looks good Geezer!
  9. NEWHD74FAN
    8,191
    98
    19
    Looking good Geezer...and your special tool fab I would recommend you post it up in the "Home Made Tool" thread below...!:s
    http://www.hdtimeline.com/general_harley_davidson_topic/28113-home_made_tools.html
  10. CalgaryBikeBum
    CalgaryBikeBum Active Member
    337
    Geezer I recommend you keep all the old covers and parts. I used mine several times already for painting ? When you want paint heads and not have problems with trying to tape things off, just use those old rocker boxes etc and old non chrome bolts. Spray to your hearts content. when you remove the old covers , Voila' perfect clean surfaces for reassembly with your nice chrome parts. Hope that idea helps someone.
