I've recently changed out my cables (idel, throttle and clutch) for my 16" Apes. Now that I have finshed installing and made some adjustments on the cables, The engine light on the bike comes on now...right after warming up. What could that mean? I have 500 miles on the bike. I refilled the transmission...but I didn't check the Primary YET. Could that be the problem?
This seems to be pretty common occurrence according to some of the folks that write to magazine techs looking for advice. However according to some other folks who had the same problem, it has to do with the sequence of the controls you use to start your Fatboy, the situation most commonly explained is similar to a computer (pc). For example have you ever turned off a computer without using the start menu? You get an improper shut down message from Bill Gates. When you turn your bike on with the switch on the gas tank from off to ignition, the computer starts a series of diagnostic checks,especially on a fuel injected model. The order of control usage is supposed to go in this order, according to the owners manual also. 1.) Turn on the ignition with the switch on the consol on the fuel tank, wait until your lights on the instrument cluster go out, 2.) Turn on the on/off switch next to the throttle. (On my FLHRSI, when you do this the check engine light comes on and the fuel pump feeds the efi system.) Wait until that light goes out. When the light goes out it is finished doing the series of checks. 3.) Push the starter switch on the handle bars. I do this every time and have never had a problem, however, I have a buddy that has a Heritage Softail Classic, he does not use this routine consistently and occasionally has this issue. In addition the tech articles state, that if you use the routine listed above after a few times the computer will clear itself out (after 10 starts). Here is the real puzzling matter, if you take it most dealers with this issue, it will not register any "error codes" on the dealer diagnostic equipment. This is just what I have read from other owners experience.
I posted this elsewhere but here goes again... Hope it helps you out. The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes). Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC). 1- Turn Ignition switch to OFF & Run/Stop switch is to Run. 2- Push odometer reset button in & hold. 3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear. 4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing. 5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.) P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted]) S = TSM/TSSM (Turn Signal/ Turn Signal Security Module) SP = speedometer T = tachometer 6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist. 7 - Record the codes. 8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear. 9 – Press and release the odometer reset button to continue to the next module. 10 – Turn Ignition switch to OFF. -------------------------- DTC FAULT CONDITION MODULE B0563 Battery Voltage High TSM/TSSM B1004 Fuel Level Sending Unit Low Instruments B1005 Fuel Level Sending Unit High/Open Instruments B1006 Accessory Line Overvoltage Instruments B1007 Ignition Line Overvoltage Instruments B1008 Reset Switch Closed Instruments B1131 Alarm Output Low TSM/TSSM B1132 Alarm Output High TSM/TSSM B1134 Starter Output High TSM/TSSM B1135 Accelerometer Fault TSM/TSSM B1151 Sidecar BAS Low TSM/TSSM B1152 Sidecar BAS High TSM/TSSM B1153 Sidecar BAS Out of Range TSM/TSSM P0106 MAP Sensor Rate of Range Error Carb P0107 Map Sensor Failed Open/Low Carb P0107 Map Sensor Open/Low EFI P0108 Map Sensor Failed High Carb P0108 Map Sensor High EFI P0112 IAT Sensor Voltage Low EFI P0113 IAT Sensor Voltage Open/High EFI P0117 ET Sensor Voltage Low EFI P0118 ET Sensor Voltage Open/High EFI P0122 TP Sensor Open/Low EFI P0123 TP Sensor High EFI P0261 Front Injector Open/Low EFI P0262 Front Injector High EFI P0263 Rear Injector Open/Low EFI P0264 Rear Injector High EFI P0373 CKP Sensor Intermittent Carb P0373 CKP Sensor Intermittent EFI P0374 CKP Sensor Not Detected Carb P0374 CKP Sensor Synch Error EFI P0501 VSS Low Carb P0501 VSS Low EFI P0502 VSS High/Open Carb P0502 VSS High/Open EFI P0505 Loss of Idle Sped Control EFI P0562 Battery Voltage Low Carb P0562 Battery Voltage Low EFI P0563 Battery Voltage High Carb P0563 Battery Voltage High EFI P0602 Calibration Memory Error Carb P0603 EEPROM Failure Carb P0603 ECM EEPROM Error EFI P0604 RAM Failure Carb P0605 Program Memory Error Carb P0605 ECM Flash Error EFI P0607 Converter Error Carb P1001 System Relay Coil Open/Low EFI P1002 System relay Coil High/Shorted EFI P1003 System relay Contacts Open EFI P1004 System Relay Contacts Closed EFI P1009 Incorrect Password Carb P1009 Incorrect Password EFI P1010 Missing Password Carb P1010 Missing Password EFI P1351 Front Ignition Open/Low Carb P1351 Front Ignition Open/Low EFI P1352 Front Ignition Coil High/Shorted Carb P1352 Front Ignition Coil High/Shorted EFI P1353 Front Cylinder No Combustion EFI P1354 Rear Ignition Coil Open/Low Carb P1354 Rear Ignition Coil Open/Low EFI P1355 Rear Ignition Coil High/Shorted Carb P1355 Rear Ignition Coil High/Shorted EFI P1356 Rear Cylinder No Combustion EFI P1357 Intermittent Secondary Front EFI P1358 Intermittent Secondary Rear EFI U1016 Loss of ICM/ECM Serial Data Instruments U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM U1064 Loss of TSM/TSSM Serial Data Carb U1064 Loss of TSM/TSSM Serial Data EFI U1064 Loss of TSM/TSSM Serial Data Instruments U1097 Loss of Speedometer Serial data Carb U1097 Loss of Speedometer Serial data EFI U1097 Loss of Speedometer Serial data TSM/TSSM U1255 Missing Message at Speedometer EFI U1255 Serial Data Error/Missing Message EFI U1255 Serial Data Error/Missing Message Instruments U1255 Serial Data Error/Missing Message TSM/TSSM U1300 Serial Data Low Carb U1300 Serial Data Low EFI U1300 Serial Data Low Instruments U1300 Serial Data Low TSM/TSSM U1301 Serial Data Open/High Carb U1301 Serial Data Open/High EFI U1301 Serial Data Open/High Instruments U1301 Serial Data Open/High TSM/TSSM 2006 models with 02 sensors (Dynas) P0131 Front 02 sensor lean for any length of time P0151 Rear 02 sensor lean for any length of time Above codes can also be set if 02 sensor fails. ----------------------- AFR – Air Fuel Ratio ATS – Air Temperature Sensor BAS – Bank Angle Sensor CCM – Cruise Control Module CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the ECM where it is used to reference engine position (TDC) and speed. Home position established by taking readings off the 22 teeth on the alternator rotor. DTC – Diagnostic Trouble Codes ECM – Electronic Control Module. (The Computer) Computes the spark advance for proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP sensors) and controls the low-voltage circuits for the ignition coils and injectors. The dwell time for the ignition coil is also calculated in the microprocessor and is dependent upon battery voltage. The programmed dwell feature gives adequate spark at all speeds. ECT – Engine Coolant Temperature. Sensor also controls the cooling fan relay that provides 12 Vdc to the fans. EFI – Electronic Fuel Injection EFP – Electronic Fuel Pump ET – Engine Temperature sensor FI – Fuel Injectors FPR – Fuel Pressure regulator IAC – Idle Air Control actuator IAT – Intake Air Temperature sensor ISS – Ion Sensing System…detonation detection MAP – manifold Absolute Pressure sensor. The MAP sensor monitors the intake manifold pressure (vacuum) and sends the information to the ECM. The EMC then adjusts the spark and fuel-timing advance curves for optimum performance. TP – Throttle Position Sensor TSM/TSSM (Turn Signal/ Turn Signal Security Module) VE – Volume Efficiency VSS – Vehicle Speed Sensor. Used as an input for idle speed control
Les, that will work on 04 and later bikes. This is for the earlier bikes. 00-03 HD Codes And Activation - Harley Davidson Community
