wlbowers
On the newer dyna's (2006 up) if you remove the oil filler plate you can access the return port for the oil. It will be the top hole under the plate.
Take a plastic hose 90º fitting the right size. You can buy them at lowes or get vacuum hose fitting at autozone. You can do the same thing you see on rogue's site.
Put the 90º on the hose and hold it in the hole.
Make your own oil puck.
This is for 3/4"-16 threads for the oil filter. Summitt Racing has these for different threads.
1 - Perma-Cool 111 $11.95 + 4.95 shipping.
1 - 1/8" pipe plug
2 - 1/2" pipe plugs
2' - hose to slide over the return line. Walmart or lowes around $3
I drilled sideways through to combine the chambers. I drilled down through one of the ports to enlarge the hole.
The 1/8" pipe plug goes in the sideways hole.
I used brass plugs because I had them. Galvanized or black pipe will cost less than $3.
1 - 1/8" pipe plug
2 - 1/2" pipe plugs
