Yes, CVO'S do not have any connectors inside bars to make room for the other wires..
Here's some instructions, if you do not have the tools needed I would just take the bars with the connector still on to your local dealer and if he's a good dealer he will pop them off for you in two seconds at no charge. or I would pick up a electrial diagnostic manual and MOLEX ELECTRICAL CONNECTOR
TERMINAL REMOVER HD-48114
Removing Terminals
1. Pull the secondary lock up, approximately 3/16 in. (4.8
mm), until it stops.
a. Socket Housing: See Figure A-25. Use a small
screwdriver in the pry slot. The slot next to the
external latch provides a pivot point.
b. Pin Housing: See Figure A-26. Use needle nose
pliers to engage the D-holes in the center of the secondary
lock.
NOTE
Do not remove the secondary lock from the connector housing.
2. See Figure A-27. Insert MOLEX ELECTRICAL CONNECTOR
TERMINAL REMOVER (Part No. HD-48114)
into the pin hole next to the terminal until the tool bottoms.
a. Socket Housing: The pin holes are inside the terminal
openings.
b. Pin Housing: The pin holes are outside the pins.
3. Pressing the terminal remover to the bottom of the pin
hole, gently pull on the wire to remove wire terminal from
its cavity.
good luck
