change your fork oil
Discussion in 'General Harley Davidson Topic' started by tommylucky, Sep 9, 2011.
  1. tommylucky
    tommylucky Member
    5
    singly . the most overlooked part of your bike. changing you fork oil will make your bike ride better. dont be a schmoe..change you fluids regularly. changing your brake fluid is a good idea too.
    the life you save......
  2. NEWHD74FAN
    8,191
    98
    19
    For a new face on HDT you have a lot of wisdom in those words. Fluids change and routine maintenance done correctly and on schedule will save more than the few dollars doing it yourself. That is the fundamental reason why forums like HDT exist...:D
  3. Mongo1958
    Mongo1958 Junior Member
    738
    23
    Hey Shmoe! Nyuck Nyuck Nyuck!!! Heh Heh, I crack me up!!!:lolrolling
    All kidding aside, that’s great advice. My other bikes would need the fork oil flushed at about 25K miles. In addition the bushings would need to be replaced too.
  4. SE6A
    SE6A Active Member
    102
    3
    ...Just changed my oil on my 99 softail standard, after searching for a friend with a spanner to fit the top nut, used a quality snap-on adjustable in the end it worked a treat with no scratches or dings!...interestingly the oil that drained from both legs was different...one leg it was black the other more a very dark green...so the guy before may have used two different oils..or just changed one leg?...back on the road...and it just started to rain!!
  5. 03HD883R
    03HD883R Active Member
    167
    On my sporty I installed new top caps that have an allen so you don't have to jack the bike up to swap the fork fluid. Makes it a whole heck a of lot easier than fighting the spring pressure too.
