nascar7613
08 Road King. Stock compensator took out ring gear. Replaced with SE compensator, new clutch hub & basket, inner primary bearing,Twin Power manual chain adjuster and new chain. A couple months later, the stator went out. Took everything apart to replace stator and found a lot of metal stuck to the rotor magnet. Cleaned it up, couldn't see where all the metal came from. Put it back together and when adjusting the chain on the tight spot at 5/8", spin the motor around to check the adjustment and found that the loose spot on the chain is just over an inch, spin it to the tight spot again, still 5/8". When the bike is running it sounds like a box of rocks. It's got to be the chain bouncing around, what would cause a new chain to be so inconsistent?
