Cam Replacement
Discussion in 'Other Service and Maintenance' started by zoood, Oct 31, 2010.
  1. zoood
    zoood Junior Member Product Contributor
    663
    5
    Im about to put a new wood's W6H cam on my Ultima 113. Ive replaced cams in my evos before. However. I never did any with adjustable push-rods. The Ultima has adjustable push rods. Im seeing where people have been saying to find TDC. Im lost at this. Without the push rods in there. How can I be sure to find TDC for each cylinder?
    zoood
  2. Hoople
    Hoople Account Removed
    7,198
    34
    You can put anything (a pencil) on top of the intake lifter. Crank the engine by hand. After the intake lifter goes back down to its base circle, the piston is approaching TDC on the compression stoke.
  3. glider
    50
    A straw works better with less chance of anything breaking off in the cylinder.
  4. Jack Klarich
    TDC gauge will work also:s
  5. zoood
    663
    5
    Cant I just locate TDC by looking in the timing plug hole on the other side of the engine?
  6. Jack Klarich
    Sure if you can see it, and keep in mind the hole is worth about 5 degrees of timing
  7. Hoople
    7,198
    34
    A what?
  8. glider
    50
    A who?
    It's like a dial indicator that screws into the plug hole. Not a very common tool to find. It has an arm that contacts the piston and a dial on the outer face that corresponds with the arm movement.
    Looks like this one but they come in different configurations for the application.
    [​IMG]
  9. Hoople
    7,198
    34
    Wait a minute. Are you trying to find TRUE TDC or just TDC of compression. If you need TRUE TDC, that requires a piston stop and degree wheel.
  10. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Yes, no. You could be on the wrong stroke. I do both of what Glider and Hoople said. A straw in a spark plug hole, and something on the cam or lifter, makes sure I'm on the correct stroke.
