BUBBIE
Well-Known Member
Hey gents, when did they switch to the Torrington inner cam bearings? Or did they switch away from them? In any case, I'm coming rapidly upon my 20K mark on my '03 RK (late), and am strongly considering going to the hydro-adjusters. Just wondering if I need to plan/save for the inner cam bearings as well. If I don't need the bearings, I will likely do my own wrenching, but if I need the bearings, I don't trust my skills to be able to "press" the new ones in,and will have to go with a pro.
As long as I'm in there, I might go with a mild cam upgrade as well. I'll be completing a home-grown stage-1 very soon. I already have Hooker Tuned-Flow slip-ons, stock ECU download, and will get an SE intake and a TFI, as soon as I get my speedo/tach (on backorder from HD). I need the tach for tuning the TFI.
Thoughts?
Enjoy,
Rich P
I WOULD CHANGE THE BEARINGS ON THE MOTOR SIDE FOR THE CAMS....
If you KNOW the dh service shop well enough, YOU might be able to HAVE them just do the bearings in and out for you... I would ALSO use the FULL bearings...Torringtons
I hear the TOOLS run a couple of $$ and ? on LABOR vs: tools?
I made a tool that worked OKAY a long time ago and loaned it out... it is still on loan...???
I used 2 OVAL (modified) washers on a 5/16 bolt with a puller set-up that fit behind bearing OR could be fitted behind engine case for either IN and OUT of the bearings... worked good.. but the bot tool better and safer....
INSTEAD OF A NEW THREAD I will ask a question BOTHERING ME
I noticed in my HD SCRM'N EAGLE parts book that the
REPLACEMENT KIT #25284 comes WITHOUT the BACK Cam Chain.... also the support plate shows it NOT HAVING the BRASS BUSHINGS for cams.
DO NEW STYLE CAMS USE THE BUSHINGS INSTEAD OF ROLLER BEARINGS on the CAM PLATE ????????
THE KIT REPLACEMENT cam plate shows(picture with out brass bushings) to use the bearings that press back into it used on the OLD STYLE CAMS..
I would sure USE the OLD STYLE CHAIN AND CAMS,,, AS it DOES USE THE newer style hyd-tensioner that comes with kit.
I would JUST make sure the older style chain DOESN"T HAVE ANY SHARP EDGES ON IT!
THIS (if i'm correct) MEANS CAREFUL YOU SPECIFY WHICH STYLE chain and cam plate YOU ARE USING WHEN ORDERING NEW CAMS!!!! This could get a little MORE confusing..
I have looked in my BIG manual on my 09 and it doesn't show a picture nor does it say anything that I found to address my QUESTION....
IF THE NEWER BIKES AND CAMS USE THE BRASS BUSHINGS TYPE,,,, I would RATHER use the OLD CHAIN AND CAM SET-UP, THEN TO GO WITH THE ADDED EXPENSE of THE different(bushing style) support plate that they sell separate of the KIT for another 329.95$
kind of jumbled up but you get the point.
