Breaking into a garage
Discussion in 'General OFF TOPIC' started by Spade5, Mar 15, 2014.
  1. Spade5
    Spade5 Active Member
    238
  2. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    I didn't watch the videos but it's an easy fix. Just tie-wrap the release arm. Tuff to open from the outside, easy to open from the inside.
  3. gator508
    gator508 Well-Known Member
    2,756
    179
    Can be prevented by using deadbolts on the side rails
  4. glazier
    glazier Junior Member
    940
    7
    but wouldn't that defeat the purpose of an automatic opener??? I can lock my garage door with the side rails locks, but then I can't open the door from the outside.
  5. SledDog
    2,120
    68
    88
    That may be a bit of a pain if you are coming home, when it's raining cats and dogs, and want to enter the garage. The deadbolts would completely disable the door, unless you were to use the type with an external key. But you would still have to get off your bike or out of your car to unlock it Using the tie-wrap or placing the cord so it can not be reached from the outside still allows for normal door use.
  6. jamesearl
    jamesearl Senior Member
    1,854
    219
    I don't have windows on mine.:bigsmiley20:
  7. glazier
    940
    7
    I don't either, but they say an experienced thief can do it by feel. Not hard to figure out the center of the door and where the rail is.
  8. gator508
    2,756
    179
    Of course, but, if security is the question!
    We know if someone wants in bad enough they are probably going to do it though, just makes it tougher.
  9. wfmacii
    wfmacii Member
    66
    This video was an eye opener. The zip tie is a great ounce of prevention. Thanks for the post.
  10. pjciii
    pjciii Member
    53
    18
    i just line the garage walls with my used gun range targets. fair warning plus a big great pyr. hopefully make someone think twice :33:
    patrick
