brakes
Discussion in 'Sportster Models' started by irishman75, Dec 23, 2014.
  1. irishman75
    irishman75 New Member
    3
    having trouble with back brakes they keep locking up
  2. stray dog
    stray dog Junior Member
    443
    Some more info would be useful.
    After you use the brake it doesn't release?
  3. dbmg
    dbmg Guest
    More and likely the pedal pivot is rusted and sticking. Disassemble pivot clean rust lube and reassemble..
  4. irishman75
    3
    i went to take off and back brakes locked up Came back to house took brakes off to realse them Went for a ride again andn once again the locked up I can push on brake pedal and the brakes lock up
  5. irishman75
    3
    is that something i could myself I know alittle about working on bikes And yes i tring to learn
  6. dbmg
    dbmg Guest
    So what you are saying is pedal is not releasing when pressure is removed.
  7. fin_676
    5,788
    153
    287
    Dirt or corrosion around the calliper piston preventing it from moving back into the calliper
    Remove calliper from its mount use the brake leaver to push the piston out just a wee bit and clean the piston
    Here is a link to replacing the rear pads on an evo softail all the same parts just on the other side of the bike but it should give you all the info you need
    Harley Davidson Forums
    The brake master cylinder may need a rebuild using a rebuild kit which replaces the cylinder and piston along with all the seals
  8. stray dog
    443
    While they are locked up, crack open the bleeder on the caliper.
    If still locked up its the caliper.
    If pistons open up, it's a bad line or master cylinder.
  9. Jack Klarich
    A collapsed brake hos will do the same thing
