brake noise
Discussion in 'Wheels' started by hyundaipro, Sep 21, 2011.
  1. hyundaipro
    hyundaipro Member
    12
    heelo i have a brake concern i have taken the front wheel off my bike and i put it back togeher to find i got the wheel spacers backwards and drove like that the front brake pedal was weak the i took off and fixed spacers when i put back brakes make a swissing noise but if i apply a little pressure on brake lever it goes away apply fully ok no noise when let off lever comes back i have bleed master cylinder no help thanks for any help
    It sounds like your caliper pistons could use a cleaning. They may be hanging u8p a bit but they will always rub a bit even when working properly.
    Harley Davidson Community
  3. hyundaipro
    hyundaipro Member
    12
    will do thanks glider
  4. Jack Klarich
    You may also try sanding the friction material and adding some Silglide or anti sieze to the backing plates of the pads and reseating them to the rotors
