Brake Noise
Discussion in 'Wheels' started by joseph.a.hart, Aug 5, 2009.
  1. joseph.a.hart
    joseph.a.hart Member
    19
    Quick question, is it normal to hear slight "rubbing" of the front brake when making turns? I dont hear it when going straight or when on the highway, just when I am making slow turns around the house.
  2. NEWHD74FAN
    8,191
    98
    19
    A slight "swishing" sound may be heard (especially if you have "floating" multi-piece discs). If more than that, like a "moaning sound" it is likely your caliper pistons are sticking due to dry/rusty pivot pins or grunge in the piston bores that may have worked their way past the seals. You may try doing caliper service using simple handtools, Brakleen and shoe lace method per Gliders self help tip...quick and easy. Might be a good time to check if the pads are worn evenly, if one pad is worn more than the other it definitely means service is needed.
    http://www.hdtimeline.com/brakes_tires_and_wheels/2887-brake_caliper_maintenance.html
  3. joseph.a.hart
    19
    Thanks a lot, will check out link.
