Brake Lights Staying On
If you encounter the brake lever causing the brake light to flicker or stay on without use of brake, it may be due to the piston return spring not returning to proper length. This leaves lever with free play and does not contact the brake light switch properly. To correct this situation, you should use a master cylinder rebuild kit. This condition also will cancel cruise control or not allow cruise to be activated.
