brake lights 04 wide glide
Discussion in 'Electrical' started by chefrider, May 16, 2011.
  1. chefrider
    chefrider New Member
    I have gone all threw wiring for brake light, power both ends, new fuse. But both filements in bulb are both still lite up, WHY??? I have just put on LED rear and front blinkers, could this be a part of it ???
    Very possible the LED are the problem. You need a load equalizer to get the TSM to recognize the proper load.
  3. Jack Klarich
    Motorcycle LED Lights FAQS & Information This is what the Boss is talking about:s
  4. markols1
    markols1 Member
    13
    Have u changed ur handlebars or taken ur front brake master cylender off if u have u may have broken the stop lite swith in the brake leaver.
  5. lordharold
    lordharold Active Member
    191
    yes the old little plastic plunger will definitely do it!
    just seen that very problem on a 08 flhtcuse they took housing apart and didn't space the break lever
