thanks Glider, not sure - but I think they are HD -- most everything on the bike is HD stuff. I dont know how to post a picture. The cover appears to be bolted on using the 2 large bolts and it also have about 5 smaller allen screws located along the top side as if it were bolting two sides together??? Im sure I could get it off by just unscrewing everything - I'd find out how it went on that way. I just wish I could remove it BEFORE I have new pads installed by the 'tire' man.Many different types of caliper covers. Can you post a pic or a site that has your covers on it for more info?
thanks Glider - you are THE man. I will try getting it off tonite and let you know how it turned out.
The caliper mount bolts would be holding them on. If you remove the bolts the cover will come off and replace them to hold the caliper on then.
Thanks again Glider - last nite I took out the 2 bolts holding the caliper and removed the chrome cover - I did also have to remove 4 small allen head bolts to separate the halves to get them off of the brake line. ----but it all worked out fine - thanks for your help
