Blue Speedo Lights?
Discussion in 'Sportster Models' started by jamientrish, May 17, 2010.
  1. jamientrish
    jamientrish Member
    32
    Is there a simple way to change the lights in the speedo from orange to blue?
    I have a 2009 883C. It's flame blue pearl.
    I am looking for some low cost changes to make while saving up for an upgrade from 883 to 1200.
    50
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    You need to find out if your 883 has a bulb or led in the speedo. If it's a bulb, you can buy colored ones at most auto parts. If it's led, you're in for some expense, like the link Glider posted. I know the touring bikes use led's for the tach & speedo, and bulbs for the smaller gauges.
  4. jamientrish
    jamientrish Member
    32
    Is it as simple as taking off the bezel and seeing whats undreneath?
  5. glider
    50
    Most speedo bezels are crimped on but they can be removed with some care by lifting them up carefully all the way around the speedo.
  6. jamientrish
    jamientrish Member
    32
    Thanks all. I'll probably talk to my trusty Harley guys about the upgraded speedo/tach.
  7. Breeze3at
    4,926
    224
    If it's crimped like Glider suggested, the lights are probably led, and part of the wiring harness. I was thinking the speedo was in a cup with a couple of nuts on the back, and easy to get apart. My last sportster was an '87 and tach and speedo were in cups.:D
