blowing battery fuse
Discussion in 'Electrical' started by bsawvel, Apr 23, 2009.
  1. bsawvel
    bsawvel Member
    7
    Had battery on a charger and tried to start bike, it did not have enough juice and it blew the battery fuse. I put a new battery in but the fuse instantly blows. everything works but the inginition switch. Any ideas what could be wrong
    50
    If it blows when you install a new fuse, there';s a short to ground and you have to locate it.
  3. bsawvel
    bsawvel Member
    7
    Any idea of the best way to find it? I have tried everything I can think of and have failed. I hate to trailor it in to the shop if it a easy fix and I just ain't getting it.
  4. glider
    50
    Best way is to visually inspect the cable from one end to the other.
  5. bsawvel
    bsawvel Member
    7
    Thanks for the help, it ended up being the starter stuck in a bad spot once I got it to move, I quit having fuses blow. Now my speedo and odometer won't work...... I will get through this eventually..
