Bike Wont start
Discussion in 'Engine, Fuel and Exhaust' started by fight4yourrights, Aug 27, 2013.
  1. fight4yourrights
    fight4yourrights New Member
    I have a home built chopper. It has a 1986 evo motor. I had put stable in the tank and had stored it for 6 months. I tried to start it and the starter cranks and turns over but it doesnt catch. I have spark, took apart the mikuni carb and cleaned it and it is getting fuel. Battery is fully charged. I also dumped the old fuel and put fresh in. Have two new plugs in as well. Anyone have any ideas on what Im missing?
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    IF you have compression, fuel and spark .... It should fire or pop...
    I think Unless the plugs are wet, you have no fuel getting into the motor.
    Check them (plugs) after a Kicking over and look to see if Wet...
  3. Jeff Klarich
    4,798
    103
    485
    Does it fire like it's trying to start? key/ign on? Does it look like gas is getting to the plugs.
  4. STEVE07
    4,124
    68
    84
    Try shooting a SMALL amount of ether into the throat of the carb and see if it tries to fire. That will either tell you or eliminate lack of fuel to the cylinders.
  5. Jack Klarich
    Before you try this run a compression test
