bike wont crank over
Discussion in 'Sportster Models' started by critter45, May 17, 2011.
  1. critter45
    critter45 Member
    6
    my o2 sporty1200 custom I hooked up a cig lighter to the coil like a (Edit)
    it worked but.... It went about 2 blocks and it coughed and died now it wont kick over I have lights horn blinkers just wont kick over and will not push start. need help is there more than one fuse in the bike
    Please read this...
    [note]
    [/note]
  2. HDDon
    5,542
    133
    229
    Go back to the last thing you did. Do you have spark? Is your bike FI or carb?
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Electrical and hooking up a Lighter.. Short would blow the fuse... check like Don says ,, More than likely there..
    Nothing should be Hooked to the coil BUT the coil...
  4. glider
    Being it ran after you hooked up the lighter for a bit, I would be willing to bet you overloaded a circuit and blew the fuse. Check your manual for the fuse sizes and replace the blown one.
    It shouldn't be hooked into the ignition circuit for starters.
  5. critter45
    critter45 Member
    6
    it is carb I dont know if i have spark because
    it wont turn over
    if i blew a fuse would the lights and etc still work?
    it is carb and i dont know if it has spark cause it wont turn over to see if it does I dont know how else to check it
    If it blew the fuse would it still have lights horn etc.
    where would the fuse be at to check it I found the 30 amp fuse but that is the only one i found
    I dont have a mauel for this bike is there somewhere i can download a free one.
  6. glider
    Lights, Ignition etc are on different fuses, Check them out first.
  7. Hoople
    Hoople Account Removed
    7,198
    34
    Don't use the same "free" site I tried. Mine also came with a Free virus.
  8. glider
    You can at least get the owners manual from the dealer. They aren't expensive.
  9. critter45
    critter45 Member
    6
    WHOOOO HOOOOO
    it was a fuse so i went to advanced auto and got a pack of 15 amp fuses
    replaced one in there and it is purrrrrrrring like a kitten
    If i would have looked I would have seen there was 2 extra fuses incase one blew. oh well I got lucky
    wont be hooking up a lighter to that anymore
  10. glider
    Wasn't that easy now? :D
    Always suspect the last thing you did as the problem.
