Fearless1
I was coming home from work yesterday and turned into my subdivision and pulled in the clutch and bike died. Well with the switch off the wire that goes from the small black block in front of the battery to the voltage regulator jumps and clicks every few seconds and it archs pretty good when you try and hook up the hot to the battery. Can this be caused by the voltage regulator? Any1 else ever have this happen or any suggestions would be highly appreciated? By the way the wire jumps like I stated even with the switch off.
99 twincam 88 EFI
Forgot to mention the 6 blocks I had to push the bike home at over 100 degrees.:bigsmiley29:
99 twincam 88 EFI
