big sucker stage 1 or stage 2
Discussion in 'Engine, Fuel and Exhaust' started by wideglidehog01, Sep 8, 2011.
  1. wideglidehog01
    wideglidehog01 Member
    5
    Is there any difference between the backing plate of an arlen ness big sucker stage 1 or stage 2? :33:
    Your best bet would be to contact the AN company and check with them.n More than likely it's the same plate with a taller filter.
    Arlen Ness
  3. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    It appears the backing plate is the same, stage II filter is bigger. Below is cut/pasted from A.N. website.
    Stage I kit features a Team-Ness High-Flow filter that accepts all 1993 and up oval or round OEM outer covers. Stage II kit features a 20% larger Team-Ness High-Flow filter that requires an 8" round Ness or OEM outer cover.
    All kits include a "Big Sucker" aluminum backing plate, Team Ness High-Flow air filter, chrome banjo bolts for Twin Cam 88 and 1993 and up EVĀ² Big Twin, simple instructions and all necessary hardware. "Chrome" Sucker kits include a Smooth-style, steel, chromed cover. Kits available with either satin or chrome backing plate.
  4. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    If I'm not mistaken, the stage 1 has 3 bolts holding the filter on and the Stage 2 has 4.
  5. wideglidehog01
    5
    called arlen ness and the backing plates are the same for stage 1 and 2 for the big sucker.
  6. Bodeen
    4,643
    73
    221
    If they are still made the same then they are both poorly made and stand a good chance of breaking. Get a K&N or an SE. Ask me how I know.......................:D
    Bodeen
