Best CCA battery
Discussion in 'Softail Models' started by mnkymn1, Dec 12, 2009.
  1. mnkymn1
    mnkymn1 Member
    37
    I'm looking for the highest rated, best battery i can find....I know that (typically) CCA's are measured at 32 degrees F but which bettery is rated the highest and performs the best in VERY cold temps? I have looked at the oddysey and big boar and scorpion...just not sure
  2. NEWHD74FAN
    8,191
    98
    19
    Modern batteries are designed with the highest plate density as possible with minimum amount of electrolyte...what this means is the tiny bit of water can be boiled off, hence the "water conserving" technology is "all the stir" (in the lead acid battery industry). Advantage, higher power delivery (desnser plates), more concentrated electrolyte (less water manintenance needed)...downside if battery discharges very low...water concentration is up...now prone to freezing AND much less CCA when cold...the worst case for battery operation. For best results, a fully charged battery deilivers best overall performance with no downside. This is why we recommend a Battery Tender to keep surface charge up.
  3. Hoople
    Hoople Account Removed
    7,198
    34
    Man, You must be a Navy Seal or a Marine to be riding in below freezing weather. Low 50's and I am heading indoors!....
  4. mnkymn1
    mnkymn1 Member
    37
    haha...nope just a die hard rider...so much so, that i refuse to own a car or truck
  5. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    East Penn Mfg. Co. claims to be supplier of HD oem batteries. They sell one under the "Deka" brand that might be a few $ cheaper than the dealer.
  6. dangerdan
    dangerdan Junior Member
    922
  7. Jack Klarich
    Never had a problem with H D batteries, I do know Sears batteries are not up to the test
  8. NEWHD74FAN
    8,191
    98
    19
    FYI, the battery for my Sportster DOES NOT have an exact replacement in the aftermarket brands like Odessey...but the good news is HD Battery does use latest Electrolyte Conserving Technology, packaging high density plates with thin separator design in thin plastic case [basically all the elements of modern batteries by Yuasa (probably their OEM maker) and others].
    Like Smitty & Jack K stated, the HD Battery works just fine...just remember to use a Battery Tender to keep the surface charge up...you will do fine, even well below freezing. Keep in mind, that you may want to put a switch in (or cutout relay) to keep the headlight OFF during cranking...every little bit of parallel current lost to non essential accessories is taking away from the CCA reserve of the battery when starting.
  9. maine-e-axe
    maine-e-axe Junior Member
    732
    I bet if you cover the bike with blanket (or bike cover) :newsmile078::small3d009:and put a drop light next to the motor it will keep the motor warm enough to start.
  10. Wayne R
    Wayne R Active Member
    228
    Last battery I bought was a HD battery, almost bought a Die Hard, I guess im glad I didnt, Anybody know who makes the battery for HD?
