Bag Liners?
Discussion in 'Other Service and Maintenance' started by dkamp, Feb 14, 2016.
Tags:
  1. dkamp
    dkamp Member
    13
    I followed the general info on this link:
    http://www.baggersmag.com/motorcycle-gear/diy-saddlebag-liners
    and did my own bag liners. I do have to say it looks great.
    I made templates for each side by taping copier paper to to the inside bag. and over lapping the paper in different areas helps the template to be accurate. Repeat for the tops and bottom.
    went to local home improvement store and bought enough "Trunk Liner" carpet.
    Cut each piece from the templates, sprayed 3M glue and pressed one side at a time holding in place paying special attention to the corners and top edge. repeated on each side and again paying attention to the seams. Cleaning up any over spray drips with Mineral spirits. Kept revisiting each side and corners to keep it stuck where it should be formed. The Trunk liner does stretch a bit so use that to your advantage but don't rely on it on every seam. It turned out way better that I hoped.
    Experienced learned is to take your time making the templates, use straight edges when possible, and dry fitting each piece before applying spray glue. and rub everything to keep it in place.
    Jack Klarich likes this.
  2. Jeff Klarich
    Jeff Klarich Experienced Member Contributor
    6,141
    183
    951
    Good tip, thanks for sharing.:)
  3. dkamp
    dkamp Member
    13
    There are vendors who sell precut pieces to make it easier.
  4. rusntx
    rusntx Junior Member
    412
    56
    I admire your patience, that's the kind of task I just can't seem to tackle. Good on ya, likely saved quite a few bucks and who knows may have been a reason for an adult beverage or two.;)
  5. joel
    joel Senior Member
    1,912
    133
    517
    Sounds like quit a task , just glad my bike came with them, they are nice, gives you another place to use the vacuum when cleaning.
