Back Light blinker for 09 Road Glide
Discussion in 'Touring Models' started by Jim B., May 15, 2010.
  1. Jim B.
    Jim B. Junior Member
    518
    I have one of those gadgets on my 05 Goldwing that flashes the brake lights a few times when the brake lever is pulled. Are there similar devices for single brake light systems like those found on the 09 Road Glide? Thanks.
  2. hogrotten
    hogrotten Junior Member
    642
    5
    Yes I believe there are several, the one I use on my bike had to be hard wired in and flashes the brake light three times then steady then repeats.I don't recall the brand but jpcycles or dennis kirk should have them.:s
  3. ironmark
    ironmark Junior Member
    754
    5
    I had a Back-Off brake light module from J&P cycle but it hard wires in & I am not cutting any wire on this bike .
  4. HDDon
    5,544
    133
    229
    I got an LED flasher off ebay. It is a direct replacement for the OEM bulb.
  5. rsmith4604
    rsmith4604 Banned
    15
    Ridetimetechnology.com is a good company to start with.:s
  6. tkeswede
    tkeswede Member
    76
    18
    I had one on my 2000 electra glide which I moved to my 09. I got one of the trailer wire connectors and cut into those wires so I didn't cut into the factory wires. Makes it very easy. Got mine from J&P. I just hooked the flasher into the stop lights and made it so I could disconnect it if I needed to.
  7. ultrat
    ultrat Senior Member Contributor
    1,315
    mine is called Back Off used it on several bikes 38.00 i like it & my wife said it does get your attention...
  8. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
  9. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    "Tailstopper" is another brand. It's plug & play. They make a couple of different modules, one just flashes your current light, one converts turn signals to running lights, etc. They have them on ebay, or you can google to find another seller.
