B+ connector
Discussion in 'Electrical' started by nascar7613, Dec 28, 2012.
  1. nascar7613
    nascar7613 Active Member
    241
    38
    5
    I am trying to find the B+ connector on a 2003 Heritage Softail. I thought it's supposed to be under the seat in the battery area, but I do not see it. I removed the battery to see if it somehow got stuffed under there, but it's not. If anybody knows where it is and could tell me I sure would appreciate it.
  2. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    What is the B+ connector?
  3. Rubyred
    Rubyred Senior Member
    1,020
    12
    Did you look forward of the battery tucked in among a bunch of other wires? Gray connector with a single red wire going to it.
    [​IMG]
  4. Rubyred
    1,020
    12
    Just looked at drawing it shows that the red wire goes to the starter and regulator and it is connected in between. It also shows it near a 30 amp connector. Breeze I believe this connector can be used to connect to a GPS or other unit needing power. It is tied to the ignition switch.
    [​IMG]
  5. Rubyred
    1,020
    12
  6. Breeze3at
    4,921
    224
    Thank you for the info. I was not aware of that connector.
