i am going to put ar cones in my drag pipes.Question is; do i also use gaskets in the pipes as well or do the cones pose as gaskets? also is it myth that without backpressure u can toast a valve?BTW the bike is a 95 xlh 1200
Interesting!
TQ - Is this indicating that you could run the less expensive "drag pipes" with AR's installed and not lose performance? .
Thanks Breeze - I have brand-new Bassani's so I'm not buying anything for a long time. But I do have dreams of a DIY bobber some day and there are some snazzy looking drag pipes out there for under 2 bills...
Interesting!
TQ - Is this indicating that you could run the less expensive "drag pipes" with AR's installed and not lose performance? I know that when I shopped for my current pipes, my Bassabi's were about the least expensive while still having some decent style, unless I went with open pipes. I didn't go open because I knew that you loose back preasure and performance...
