Alarm
Discussion in 'Softail Models' started by Goofuss, Mar 21, 2008.
  1. Goofuss
    Goofuss Active Member
    131
    I just bought a 2006 Softail Std. I want to enter a personal code, but the instructions they give you don't really click with me. Can somebody tell me what to do? Thanks
  2. dynarider
    dynarider Member
    94
    Hopefully it's the same, In my '07 owners manual it says to assign a pin by:
    pick a 5 digit number (ABCDE)
    turn ignition key on-off-on-off-on quickly
    left turn signal 3 times
    right turn signal 1 time
    turn signals should flash 3 times, the current pin should show with the first
    digit flashing.
    enter 1st digit (call it A) by pressing left signal A time(s)
    press right signal to set 1st digit (new A replaces old A in pin number)
    enter 2nd digit (call it B) by pressing left signal B time(s)
    press right signal to set 1st digit (new B replaces old B in pin number)
    repeat for numbers 345 represented by CDE in your pin
    after setting E, turn off key before the security module rearms to set the
    new 5 digit code.
    and welcome to the forum!
  3. Goofuss
    131
    Thanks I will give that a try.
  4. dynarider
    dynarider Member
    94
    You're welcome. I guess saying,
    "enter 1st digit (call it A) by pressing left signal A time(s)" may not be totally accurate.
    More like press the left signal button until your "A" number shows. Say you picked 6,
    and it was set as 2 by the dealer, if you clicked it 6 times then it would be wrong.
  5. Goofuss
    131
    How do I tell if it was set already?
  6. dynarider
    dynarider Member
    94
    When you get into setting mode it will/should show the current pin number. The H-D default is something like 31313 or 13131
  7. glider
    50
  8. Goofuss
    131
    Thanks
  9. stay cool
    stay cool Member
    10
    You need a helper, have someone read the directions as you do the work it help's.
    Stay Cool
