If you have a problem with the shocks not holding air, you can check it with some soapy water solution in a spray bottle and direct it around the fitting connections in the system.
The later model touring bikes have had quite a few problems with the system leaking down in a short period of time and not maintaining the pressure set by the owner.
Most cases of this leakage has been found to be the Schrader valve is not tight enough and needs to be snugged down. In some cases a replacement valve is necessary if the leakage continues.
