After market radio systems ?
Discussion in 'Touring Models' started by ironmark, Jan 9, 2009.
  1. ironmark
    ironmark Junior Member
    754
    5
    I was riding with a few friends yesterday & one of them has a HD Standard & was wondering if he can install a aftermarket sound system . What aftermarket systems would be good for him to look @ ?
  2. gsxrboy96
    gsxrboy96 Member
    35
    Yes, do some research, i am going thru this right now with my standard, The simplest thing ive found is the bike tronics module with the sony marine radio they reccomend, but thats nearly 400 bucks no matter which way you stack it,
  3. Animal
    Animal Active Member
    385
    Check out Hogtunes, I am glad I did!
  4. STEVE07
    4,128
    68
    86
    The marine radios still have more output and are much more waterproof then the HD radio as soon as my HD radios need repair I switch to marine JMO
  5. glider
    50
    If I remember correctly the marine radios (CB's) put out 25 watts on high power.
  6. STEVE07
    4,128
    68
    86
    When I get to the shop I will pull out the sheet on the Delco I put in the boat last summer and scan it in ,But it is full 80 watts a side. I went with the Delco marine because it is made by Bose
  7. glider
    50
    I edited my post. I was talking about CB radios. Sorry for the mix up. It's early yet! :D
  8. STEVE07
    4,128
    68
    86
    Need a little solder on that motherboard?:D You knew I had to comment!
  9. glider
    50
    My flux capacitor is low on flux! :rofl
  10. STEVE07
    4,128
    68
    86
