afr guage
Discussion in 'Engine, Fuel and Exhaust' started by marknett, Nov 16, 2012.
  1. marknett
    marknett Active Member
    205
    I notice the new gen 4 controller has a afr guage with to tell you where you are on your mixture ..Can you do this an add-on for other units as a reference tool?
  2. Hoople
    Hoople Account Removed
    7,198
    34
    If you mean to use the unit as a "stand-alone" A/F ratio meter,,, I spoke to them awhile back and asked the same question. No, it can't be used in that way.
  3. marknett
    205
  4. STEVE07
    4,125
    68
    85
    Why not just go with the Gen4?
    It comes with the AFR guage and that is where you set the tuner from.
  5. marknett
    205
    the gen 4 is not offered for my bike yet :)
  6. Hoople
    7,198
    34
    Interesting product. Purchase price is not cheap but rental price is certainly fair. You could do a bunch of testing/tuning in a week. It would be awesome to rent a pair and do both cylinders in one shot.
    I wonder if can just install the wideband sensor into the factory bung if you wanted to,,,(instead of using the nutsert tool)?
  7. glazier
    glazier Junior Member
    940
    7
    Other than the AFR gauge, is there any difference between the Gen3 or Gen4??? And can the gauge be removed after the TFI is all set??? I'm not crazy about having that gauge mounted to my bars permanently. And then later on if I do some other mods, can I hook up the gauge again to reset the TFI and then remove it again??? Or are these questions I should call Dobeck about???
    Thanks.
