Adding TFI to stock 09 flhx
Discussion in 'Touring Models' started by Redman, Feb 19, 2009.
  1. Redman
    Redman Active Member
    272
    Good day all....does adding a TFI unit to stock bike make sense...want to cool it down a bit and add some fuel...was wondering if this is goiing to make a difference without air cleaner or pipe change. Thanks in advance for your help.
    50
    Yes, you will notice a better running bike even with the stock exhaust and intake. The factory/EPA has these bikes running very lean.
  3. Redman
    272
    Thanks fellas just tryiing to plot a cost effective path for improvement over stock ....to lean from what I have read. Added spectro 6 speed tran fluid and mobil 1....thanks to your suggestions...what a huge difference the tranny fluid made IMO.
  4. glider
    50
    The TFI can be reset to include any updates to the exhaust or intake at a later time.
  5. Redman
    272
    Thanks glider that was my next question...as I am sure you suspected.
  6. TQuentin1
    4,737
    142
    When I did my Stage 1, I foolishly paid for the HD std. 1450 Stage 1 upgrade to the ECM (of course that was before I had found HDTimeline!!). Now I am about to do the roller chain conversion (you don't have to worry about that one!) on my '03 UC and am adding different cams in the process. The TFI arrived in the mail the other day from Dobeck Perf.!! Just waiting on a few more bits, and then I start this little project!
  7. glider
    50
    Don't forget the pics!:D
  8. Bud White
    3,270
    TFI is for sure the way to go .. easy to tune .. I would go with it esp if you plan on upgrades later ..
  9. ramnj
    ramnj Member
    20
    What is TFI??
  10. glider
    50
