bgrant64
Hi all,
I am about to do the camplate upgrade on a 06 EGC to change over to the new style tensioners. Since the SE camplate upgrade comes with the new style oil pump would adding a Baisley spring be a good idea or with then new oil pump with better volume and I am assuming pressure capability will it not be needed?
Also since I am doing this upgrade and adding SE 204 cams while they are doing the camplate upgrade, would it be a good idea to add adjustable pushrods while I am having this done? Would the SE tapered adjustables be a good choice if it is?
Thanks for any thoughts,
Brad
Brad
