'98 heritage softail carb question
Discussion in 'Engine, Fuel and Exhaust' started by eire1400, Nov 22, 2010.
  1. eire1400
    eire1400 Member
    14
    Hello from Ireland. Ive an evo engine 98' heritage softail and I've a few questions too:
    See pic.
    What carb comes as standard on these? can u tell from the pic is this standard? Is there a restricted back plate on this model? Any other info gratefully received!! thanks in advance.
  2. fin_676
    5,779
    153
    285
    To get a better look at the carb remove the filter backing plate by removing the three pillar bolts and the two breather bolts that go into the heads take note of any washers and their respective placing
    however from what i can see it is a stock keihin cv carb
  3. Jack Klarich
  4. karlsbike
    karlsbike Active Member
    264
    3
    That's a stock 40mm Keihin CV carb with accellerator pump and a performance a/c backing plate - probably S-E.
    The carb was used on BT's I believe from '88 & Sporty's from '89
    What do I win?
  5. eire1400
    eire1400 Member
    14
    Thanks again Karl, So no need to upgrade my back plate then! One less off the LIST!!
  6. karlsbike
    264
    3
    Plenty of info on how to tune & upgrade those CV's around - also ref my earlier post.
    You should know that it is a good performer - it will keep up with most anything you throw at it if you keep the original engine size.
