88Twin Blown Motor
Discussion in 'Oil' started by jwhulon, Apr 19, 2010.
  1. jwhulon
    jwhulon New Member
    Hi Fellows
    I have an 05 Softail That Broke the oil pump Gear and Screwed up the Crank
    Was Wanting some input on build it or by a HD Reman Engine? Never worked on Harley'S But have 30 years Wrenching on Big Truck's
    I was looking at The Upgrade to 1550 Big bore From Hd About $3500 wasn't sure If i could upgrade power and build the 88 for less, I see there seems to be a lot of Special Tooling you need to work on these Girls Any Help would be Appreciated
  2. Jonas
    Jonas Junior Member
    408
    Did the camshoes cause this? Just wondering. I do not have input on the build
    Good Luck
  3. Jack Klarich
    If you want to keep your original vin on the motor I would go with The MOCO reman program JMO
  4. HDDon
    5,542
    133
    229
    I did the reman on my 94 Softail and it is the best deal out there.
  5. Slowrider
    Slowrider Active Member
    119
    Another advantage with the reman is the 12 month unlimited mileage warranty.
  6. ooheritage
    ooheritage Active Member
    132
    what is the cost on the reman, and don,t they do extra stuff on like an 2000 which would be like roller bearings instead of ball bearings, upgraded oil pump and the hydraulic cam tensioners?
  7. glider
    Check out the self help area, it's all in there...
    Engine Remanufacturing - Harley Davidson Community
  8. prodrag1320
    prodrag1320 Account Removed
    86
    put in a 4.375 crank and have your cylinders bored to 3.875,go with 103"
  9. TQuentin1
    4,737
    142
    Please note in the link Glider provided. It indicates that high performance cams installed in the engines sent to HD for the Reman Program WILL NOT be reinstalled or returned!!
    Call HD to confirm this. You may want to have the Dealership pull your cams BEFORE sending the engine off.
