883XL won't start
Discussion in 'Electrical' started by ryan101, Jul 16, 2016.
  1. ryan101
    ryan101 New Member
    I have a 2012 883XL I just put a new batterie in it it started and ran for like 20 min then the batteries light came on. I cut it off and let it sit over nigh before I did anything else with it I got up it started so I went to wash and after I washed it. It will now not start I have power its just not doing anything when I hit the start switch I have checked the start relay not sure what else to do please help!
  2. Jeff Klarich
    4,792
    103
    484
    Recheck all battery connections to include at the starter. Maybe water got inside the start/stop switch.
    Was battery fully charged before you put it in? Load test the battery, new does not mean it's good.
    I've seen bad batteries right off the shelf.
  3. tourbox
    tourbox Senior Member
    1,886
    168
    Once running again check your charging system.
    tourbox
  4. dbmg
    dbmg Guest
    Please do not let your steed run for 20 minutes standing still. If lights are not dropping down then no power is getting to starter. Dry out fuse box, properly bench testing battery and check all cables and go from there.
  5. Jack Klarich
