88 fxrp inner primary removal
Discussion in 'General Harley Davidson Topic' started by sons, Feb 26, 2013.
  1. sons
    sons New Member
    Hey all;
    I need a bit of help before I need alot of help. My first belt change on my bike.
    Got everything out of the inner primary, removed one "Hidden" bolt, but manual says there are 2?? I got the one a 6 oclock that holds ground strap..Any help?
    Al
  2. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    Best I can remember is there's 4 bolts to the engine, and 3 to the trans. There is one @ 6:00 in a recess under the main shaft.
  3. sons
    sons New Member
    Thanks, I'll geta bigger hammer and make4 sure I got all the bolts
    Thanks
  4. tourbox
    tourbox Senior Member
    1,885
    168
    Have you taken the starter out as well? Some of the earlier ones you had to take the starter housing off the back of the inner primary to remove it.
    tourbox
