88 fxr 1340
Discussion in 'Softail Models' started by Vilemind, Aug 4, 2010.
  1. Vilemind
    Vilemind Member
    43
    hi .. i sold my friend an 88 FXR 1340 dont know much about it ,,,he says he cant find the drain plug for the oil ,,,any help ? ... ty
    50
    Look under the tank wich is under the seat and see if you can spot the drain hose for the tank which is usually mounted to a bung that is part of the frame. You remove the hose and clamp if there is one on the hose and drain it from ther. Do it nice and hot because those tanks hold some sludge in the corners.
  3. Vilemind
    Vilemind Member
    43
    but how do i drain it from the block ?
  4. Jack Klarich
    The crank case has no drain plug
  5. glider
    50
    Don't be concerned about the engine, there really isn't that much in the engine on that bike. If you really have to to it then drain the tank and add a quart to the tank and run the engine for a few seconds and drain it again, then replace the filter and complete the oil change.
