Matt Bradley
Hey all, hoping someone can offer me some advice because I'm all out of ideas. Bought an 84 FLTC with the evo last fall from someone as a project. Bike was not running when I purchased it. Guy who had it was not mechanically inclined at all. He tried to change the bars and crossed some wires. I fixed the wiring and bike fired right up. He told me the motor had been built up by the guy he got it from but he didn't have any paperwork for it and didn't know exactly what it had. The rear base gasket was leaking so bad it was blowing oil bubbles and it was almost impossible to shift so I figured it'd be my winter project. I put about 200 miles on it before the snow came and it ran decent. So I pull the engine all apart. The motor does have high compression pistons, double valve springs, and ported and polished heads. I do not know the displacement or compression ratio. All the info on the end of the cam was ground off so I have no idea what cam was in it so I ordered an EV27 to replace it. I put it all back together with new gaskets. Set the jets at 48/195. The ignition timing gave me a very hard time. Set it with the bike warm at 2000 rpm so it would be at full advance. I checked the VOES. The cam plate is turned almost all the way clockwise (retard I believe) but I got the timing mark centered in the inspection hole. Go to take it for a test ride. Bike runs awesome at idle to 1/4 throttle under a light load but as soon as you crack the throttle, the exhaust pitch completely changes and it loses all power. It doesn't back fire or sputter. It just does nothing besides get louder and slowly gain speed. I thought the jetting was off so I tried everything from 45-50 pilot and 185-205 main and it still does the same thing no matter what. Has new plugs, wires, and coil. Do I need and aftermarket ignition with an adjustable timing advance? Could I have a bad ignition module? I am 100% sure the cam timing is correct I just don't know where to go from here.
