It is known that when an ignition module has started to fail it will only work when cold once the bike gets warm the module fails
To prove this is the case when bike cuts out remove ignition cover and spray the module with spray duster as the air comes out really cold and will cool the module down if the bike then starts and runs you will know the module needs replacing
