Thats what Ithought Iam useing Lucas 20/50 syn. The reason Iasked is Iam getting oil misting from the air cleaner Ithought heavy oil might stop it. Has anyone used reed valve thing that S&S cycle says will stop the misting ?
Stick with 20- 50, are you over full on oil, or quite possible mis aligned oil pump, check out the self help section![]()
oil level is 3qt 8oz per dealer tec
If it's got a lot of miles on it I would put 60wt in it with the heat of Texas. And the heavy tranny grease, syn in both.
Does anyone run 60W oil in TC engines The book says 60W above 80 deg . Any thoughts on this? :![]()
