Need to change trans oil to spectro 6 speed oil. Will quiet trans considerably.
Also try this:
Automatic Chain Tensioner Adjustment
Published by glider (Wise Member)
Published date: May 20th, 2008
Here's a trick to reduce the constant engine noise that sounds like valve train noises on the newer 96 Cu In. bikes that have the auto adjusting primary chain tensioners and no inspection port.
I tried this on my RKC and can notice a definite improvement. The problem seems to be coming from the primary chain and not really the valve train at all.
Here's what you do. Accelerate from a stop in first gear rather hard to about 30 MPH and then brake rather hard using only the rear brake without locking up the wheel and don't pull in the clutch until the bike slows enough.
Do this 2-3 times in succession and you'll notice that the noise that you thought was the valve train is almost completely gone now. Low speed riding is a bit smoother also due to less play in the chain.
By doing this, the automatic primary chain will ratchet up a bit tighter if it was loose before this. The acceleration and braking causes slack in the lower strand of the chain and will ratchet it up tighter if it needed an adjustment.
If it wasn't loose there will be no noted difference.
That is most likely the noise that was heard and not the valve train at all.
Sounds strange but try it!
