5th Gear Rattle
Discussion in 'General Harley Davidson Topic' started by franka, Jul 12, 2010.
  1. franka
    franka Active Member
    315
    8
    07 Road King Classic with 17,000 miles when I shift to 5th gear I hear a rattle/chirping sound especially under 3000 RPM? Seems to go away when RPM exceeds 3000? OK in all other gears.
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    franka
    This noise JUST Started ??? Wonder, what oil are you using in the tranny??
    5th gear is a straight cut gear and they do make a noise but NOT just later, IF like in yours... IMO
    get back with a few answers and we'll go from there....
  3. Hoople
    Hoople Account Removed
    7,198
    34
    Like Bubbie says, is it a new sound? Has your rattle just started and is something you never had before?
    I have what I think is the same rattle in 5th gear. I have heard this rattle since the day I drove the bike home from the dealership. It has not got any worse or better. Since I heard it since it was new, I never gave it too much thought. It only happens under light load in 5th gear. If you push some torque into the gearbox, the sound goes away.
  4. franka
    315
    8
    Yes, just atrted about 1000 miles ago has not gotten worse and as I said when I shift into 4th or exceed 3000 rpm in 5th it goes away
  5. sharpscuba
    sharpscuba Banned
    945
    Read the many post on this problem. I would be that the noise was there from the start.Spectro 6 speed tranny oil will help but not completely. Good thing is that you will know that you are in 5th.
  6. franka
    315
    8
    Using HD Tranny fluid have thought about Spectro 6 but its very hard to tell if its tranny rattle or valve train chatter
  7. Dr. Dolittle
    6,404
    118
    29
    I think you are referring to the 5th gear whine. OP is complaining about a rattle. Could be the same thing but I don't think so.
  8. glider
    Rattle, chattering, can of marbles etc. You need the IDS added to the bike. I put it on mine and it made the world of difference. Made it an entirely different feel to ride.
    The 07 baggers didn't come with it but the 08 came from the factory with it.
    Install it, you won't be sorry!:s
    IDS Drive System - Harley Davidson Community
