2014 street glide turn signal problem
Discussion in 'Electrical' started by Bowling Coach, Apr 6, 2014.
  1. Bowling Coach
    Bowling Coach Member
    having a problem with turn signal turning of before i make a total turn any ideas
  2. Dr. Dolittle
    6,404
    118
    29
    It's a 2014 - take it back to the dealer and make him fix it.
  3. Bowling Coach
    I will just like too know if anybody has had this problem
  4. hillbilly81
    hillbilly81 Active Member
    368
    my experience with more than one model is that sometimes they stay on longer sometimes not
  5. tourbox
    tourbox Senior Member
    1,902
    173
    They are a timed based circuit based on speed. The slower you are going the quicker they turn off, vice versus faster the longer they stay on. If you turn them on way before your turn it could turn off before you expect. The timer circuit doesn't start until you release the button, Press and hold the button in a little longer, then release it. See if that helps. I've never had the problem you speak of except on early '90's models.
    tourbox
  6. hillbilly81
    368
    good explanation on that tourbox
  7. Bodeen
    4,647
    73
    222
    Isn't the bank angle sensor involved too? Or is that only earlier models?
  8. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Unless changed for 2014, the bank angle sensor is involved. The BAS will turn signal off as soon as a turn (lean) is made, no matter what distance or time is involved.
  9. Jack Klarich
    This should work on all current models, good advice here Ray:s I tried it on every bike since 1992 and it works fine
