2009 Ultra 96 CI, Inner Primary removal.
Discussion in 'Touring Models' started by Mongo1958, Mar 15, 2014.
  1. Mongo1958
    Mongo1958 Junior Member
    738
    23
    I tried to do my home work but I seem to be stuck.
    2009 Ultra Classic with a 96 CI engine and 6 speed.
    I'm tring to remove the inner primary.
    I used the book to remove
    The outer primary the comp and the clutch.
    Up till now everything has gone fine.
    The book seem like a waiste of time for the stater gear.
    Can anyone halo me with this? I tried to do a search but came
    Up with squat! BTW I'm on an IPad so I'm limited.
    [​IMG]
  2. tourbox
    tourbox Senior Member
    1,902
    173
    On the back side of the inner primary there are 2 allen bolts that hold the starter to the inner primary. Once removed you can pull the starter, w/gear in place on the starter, or just let it sit there. I guess you noticed the bolts behind the clutch hub in the inner primary and the 4 bolts to the motor case. They have to come out also.
    tourbox
  3. DFHarley19
    DFHarley19 Active Member
    390
  4. Mongo1958
    738
    23
    Thanks Guys! I got it done.
