Kno Harley
Hello all, My FLHTCU has a rear break light problem. I turn the ignition switch on and when I applied the rear brake pedal, the light works momentarily and then turns off by itself and will not light up after that. Seems as if it is tripping something or other. The front break lever works fine, is only with the rear break pedal that this problem continues. I let the bike alone for a few minutes try the same thing again and the rear break light works only momentarily and turns off again. I am going crazy trying to figure out this one and with upcoming state inspection it is really bothering me. Any help, suggestions, will be greatly appreciate it. Thanks Luis
