2008 SE Stage 1 Air Cleaner
Discussion in 'Touring Models' started by crimsonultra, Feb 24, 2009.
  1. crimsonultra
    crimsonultra Member
    22
    I am getting ready to install the 2008 Screamin Eagle Stage 1 Air Cleaner and the intructions for REMOVAL #3 states to remove the fuel tank in order to remove the Support Induction Module Bracket. My question is do I have to remove the fuel tank to remove this bracket, or can the bracket be removed without tank removal? If I have to remove the fuel tank is there anything I need to mindful off? Thanks.
  2. Bud White
    3,270
    you can do it without removing tank but you risk scratching it and much time being frustrated..
    Make sure you don't break the fuel tank quick connect when you remove it
  3. glider
    You can just unbolt and lift the tank but be carefull of the fuel line over the motor mount if you lift it without disconnecting the line. It's about $45 and plastic breaks easily on the inboard end of the fuel line connection.
  4. navyman
    navyman Member
    91
    18
    I didn't remove or lift my fuel tank. You can reach the bolts without scratching your tank if you are very careful and patient.
  5. Lancer
    Lancer Junior Member
    495
    Same here, I didn't have to lift the tank until I installed the TFI
