2007 xl1200c sportster no start
Discussion in 'Sportster Models' started by 9senator2011, Oct 15, 2011.
  1. 9senator2011
    9senator2011 New Member
    Yesterday my 2007 xl1200c sporty tipped. I uprighted it and left it overnight without trying to start it. It would not start the next day. I discovered the BAS
    (Bank Angle Sensor). It is supposed to recycle by turning the switch off and on.
    I have done this, still no crank, will not even turn over. On the speedometer there is a light in the shape of a key that comes on when I turn on the ignition. I have checked all the fuses. Can anyone help? What does the "key light" indicate?
  3. dbmg
    dbmg Guest
    Did the odometer say tilt, and when you cycled key did you turn on for a minute then off for a minute and then back on???????
  4. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    I used my right grip on/off switch for about the 2nd time ever, last weekend. When I went to start the bike, the red key light came on, and nothing happened. I finally figured that the "kill" switch was still in off position, switched it on, and all was well again. :24:
  5. gator508
    gator508 Well-Known Member
    2,761
    179
    The "key light" indicates the security system, something may have happened when you tipped your bike. The procedure to reset the tip indicator is to cycle the ignition/headlamp switch ON-Off-ON.
  6. Jack Klarich
    Alarms and Security Related Issues - Harley Davidson Community may be an answer in here:s
