free website stats program 2007 Ultra radio removal | Harley Davidson Forums
mjb582003
Hi all,
I am trying to remove the radio from my ultra and have a couple of questions. Once I have removed the four screws holding it to the bracket, will it slide out forward to the front wheel? It looks like the radio front bezel might not make it past the bracket. Second question is there are 2 places the wiring harness is attached to the bottom of the radio with some cable ties that are mounted to the bottom of the radio, do these just pop out or do they need to be cut? Thanks for any help..
Mike
No the radio slides toward the gas tank if you slide it to the fender you might break the cd door. I cant remember if the wiring harness pops off or if I cut the strap on mine, its been a while, I removed mine when I changed bars but that harness is important it goes to the ign switch and needs to be removed dont want to break the connector at switch...
