I have a question. I have a 2007 Ultra classic (its stock except for the SE 255 cam) that runs fine and idles fine in temps under 85 degrees. If the temp goes above 85 it idles about 500 RPMs or dies when you come to a stop. It will start right back up. I think it's getting too hot ... I've changed the spark plugs and they are the grey-ish white on both cylinders (sign of running too lean) I've changed the air filter, as well.
I don't know how to fix it. Any suggestions or advice?
